Problem With Demetra Output
Postby Richard Brown » Sat Oct 31, 2020 10:24 pm
When I do the data reduction on a spectrum and go to 'Output' the area to 'Export To FIT' is blank. I re-downloaded Demetra with no change.
Dick
Richard Brown
Re: Problem With Demetra Output
Postby David Cejudo » Tue Jan 19, 2021 6:07 pm
Hi.
I found the same problem and found a work around.
After you run each Data Reduction process (Masters, Preprocess,...,Crop) one at a time, the Output tab shows nothing.
But then you can click the large black "RUN" button so that all the process is re-run non stop automatically. Then the Output tab works well.
So it does not work if you do the processes one by one but it does work if you do the processes all in a click.
David Cejudo.
Observatorio El gallinero.
El berrueco, Madrid.
David Cejudo
Return to Software Demetra
Who is online
x
