SN 2019vxm - a bright IIn supernova in a faint galaxy
I have confirmed and classified ASASSN-19acc as a type IIn supernova (SN 2019vxm) using my ALPY 200 spectrograph (The 31st TNS classification using this equipment)
http://www.astronomerstelegram.org/?read=13326
https://wis-tns.weizmann.ac.il/object/2019vxm
It was mag 15.6 (g) measured from the guider image when the spectrum was taken but the nearby presumed host galaxy is rather faint and until now of unknown redshift. The redshift measured from the spectrum is 0.019
The early rise was in the field of the TESS satellite so it will have a detailed light curve.
Hamish Barker
Re: SN 2019vxm - a bright IIn supernova in a faint galaxy
Post by Hamish Barker »
Great work robin! Perhaps he "alpy 200" should be a standard production variant.
This supernova is now reported to have brightened to mag 14.4 (R, clear)
https://britastro.org/comment/7485#comment-7485
If the redshift based distance (~80Mpc) is correct, mag 14.4 works out at an impressive absolute magnitude of -20.2 , thought to be boosted by interaction with circumstellar material in the case of type IIn
