Hello Valere,
Could you show us a neon file and share a raw 2D spectrum (fits file)?
Then everyone would be able to help you and understand the problem.
As I sent me your data, you may paid attention t the following:
- ccd camera has to be orthogonal to the slit: calibration lines will then be rather vertical;
- binning 1x4 leads to problems due to pixels independant response much more visible if spectra is spreaded on 1 ot 2 lines;.
Perhaps, others readers will have more comments when files are posted.
Benji
Interference ?,
Re: Interference ?,
Re: Interference ?,
I know this thread is a bit old but I have been having the same problem with the sudden jumps in the baseline that seems to be occurring intermittently when processing with Iris.
I played around with lots of settings and found that it was the cosmic ray removal that was causing the problem. If I turn it off with the problem spectra the baseline jumps stop.
Different tilt, slant, width of the binning etc made no difference but the cosmic ray tool did.
Terry
Terry
Terry Bohlsen
Armidale NSW
Australia
Armidale NSW
Australia
