Back focus Lhires & Alpy
Paul Luckas
Post by Paul Luckas »
I'm after a sanity check on the backfocus (distance from mounting plate to slit) of the Lhires and Alpy (full config) respectively.
I've found a reference on-line for the Lhires that shows a distance of 68.5 mm from the outside face of the mounting plate to the slit.
For the Alpy, I presume the distance is ~47mm - consisting of 30mm for the calibration module, plus 17 mm (half the thickness of the 34mm guiding module, assuming the slit is positioned approximately half way into the module).
Does this sound about right?
Paul
Re: Back focus Lhires & Alpy
Post by Olivier Thizy »
Paul,
the slit is actually aligned with the edge of the Alpy guiding module. So backfocus is 30mm for the calib module + 34mm for the guiding module, ie 64mm total.
