I may have access to the means to fabricate a new collimator assembly for my Lhires in order to retrofit it with a larger diameter lens for use with a 'faster' telescope - as per Lothar Schanne's version some years ago - http://www.astrospectroscopy.eu/Einstei ... sIII_e.htm
Although in practice the gains with my F/7 RC may not be that dramatic, it's something I've been considering for some time. There appears to be plenty of room inside the Lhires carcass for a larger diameter collimator, and the retrofit does not seem to be a particularly complex undertaking with access to suitable fabrication expertise.
I'd be grateful for a sanity check on the idea. Are there other factors to consider with the move to a larger (40mm diameter) f=200 mm lens - grating size, mirror size, unforeseen optical aberrations, etc? In other words, is the mitigation of vignetting the only issue to consider, or are any downsides to be expected from using a larger diameter collimation lens in the current Lhires design?
Many thanks,
Paul
Upsize collimator diameter in Lhires
Paul Luckas
Return to “Spectroscopes and Softwares”
Jump to
- Forum presentation
- ↳ Petites Annonces
- Current Campaigns
- ↳ AZ Cas
- ↳ RR Lyrae
- ↳ Be Stars survey
- ↳ P Cygni
- ↳ VV Cep
- ↳ Archives
- ↳ SN 2011fe campaign
- ↳ Epsilon Aurigae
- ↳ Novae
- ↳ T Tauri Stars
- ↳ Planetary Nebulae
- ↳ Be Search
- ↳ CH Cygni
- ↳ Novae
- ↳ Symbiotic Stars
- ↳ Supernovae
- ↳ Cataclysmic Stars
- ↳ Be Stars
- ↳ Comets
- ↳ Resources
- ↳ Miscellanous
- Spectroscopes and Softwares
- ↳ MatLab
- ↳ Python
- ↳ UVEX Project
- ↳ Sol'Ex/Star'Ex
- ↳ Software Demetra
- ↳ Software ISIS
- ↳ Software VisualSpec
- ↳ Software SpcAudace
- ↳ Software PlotSpectra
- ↳ asdb ARAS DataBase
- ↳ Android applis
- Beginners corner
- Introduction / Présentation
- ↳ OHP 2014
- ↳ OHP 2013
- ↳ OHP 2012
