At the moment I am busy making a program to model line (Hα) profiles....
Can anybody tell me how to read a 1D fit(s) file in VB?
Now I am using the .dat files generated by ISIS, but it would be nice to be able to read the .fit.
Regards Arnold
reading 1D fits files
Arnold de Bruin
Tim Lester
Re: reading 1D fits files
This NASA documentation will help. It is what I used to write my c# routine for reading 1D fit files in PlotSpectra.
https://fits.gsfc.nasa.gov/fits_primer.html
When it comes to reading the data block I found I had to reverse the byte order to get sensible numbers out.
Here is a link to the source code for my routine. It may help even if you are not familiar with c#.
https://1drv.ms/t/s!AvXqhKI5kEGRjEfjmBdgpWx8yX86
Arnold de Bruin
Great Tim!
Much appreciated
and thanks for sharing your code. Although I will be using vb, this will certainly help!
Btw, in my program I added:
If NAXIS>1 message "not a 1D spectrum" to avoid loading a 2D fits file
Regards Arnold
Much appreciated
Regards Arnold
