spectral library of 1000 stars at 2.5A resolution
Has anyone used the MILES catalogue of flux calibrated spectra?
http://miles.iac.es/pages/stellar-libra ... alogue.php
It looks quite udeful for medium resolution work as it contains almost 1000 stars at 2.5 A resolution but I cannot get VSpec or ISIS to read the fits files. (SPLAT will plot it against pixel number but does not give the wavelength)
***IMPORTANT NOTE***
The default spectra in the MILES library are corrected for interstellar extinction so cannot be used for Instrument response correction. The original as observed MILES spectra must be used. See
viewtopic.php?f=6&t=207
Last edited by Robin Leadbeater on Sat May 04, 2019 1:36 pm, edited 2 times in total.
Re: spectral library of 1000 stars at 2.5A resolution
Excellent Robin, very useful data base (ideal for LISA spectrograph, but can be also used for RI evaluation of Lhires III spectra) !
Download the very latest ISIS release (V3.4.2), you now read Miles FITS files :
http://astrosurf.com/buil/isis/isis.htm
Wow! :o
A new version of ISIS in just 3 hours and at 02:30 :)
Thank you Christian
You can now directly consult the majority of MILES library base under
ISIS solution (V3.4.3) :
http://astrosurf.com/buil/isis/new/release.html
http://astrosurf.com/buil/isis/isis_en.htm
Eric Sarrazin
Post by Eric Sarrazin »
Merci Christian! Je viens d'essayer. Tout fonctionne bien. Belle réactivité.
Une belle trouvaille de Robin. Many Thanks Robin.
Eric
