Hi! I hoped to use AudeLA for acquisition but I don't manage to get past a simple problem - I get an error message when I press the Setup button in Camera Setup/ASCOM dialogue box:
setupDialog error CreateInstance hr=80004002
while executing
"ascomcam setup $private($camItem,modele)"
(procedure "::ascomcam::configureDriver" line 11)
invoked from within
"::ascomcam::configureDriver "
invoked from within
".audace.confCam.usr.onglet.fascomcam.frame1.frame3.configure invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 24)
invoked from within
"tk::ButtonUp .audace.confCam.usr.onglet.fascomcam.frame1.frame3.configure"
(command bound to event)
All other SW works OK, I can use the ATIK cameras in Artemis, ASCOM self-diagnoses fine and works well with CdC and EQMOD.
Any ideas what I could try?
Cheers, David
Audela/ATIK setup problem
Re: Audela/ATIK setup problem
David,
One of the most comprehensive explanations of installing ATiK cameras under Audela is contained in the LISA manual......
http://thizy.free.fr/shelyak/Lisa/DC001 ... -%20En.pdf
Thanks Ken, thats what I did. I've tried to un-install and instal as well. Now I'll try another laptop... /Cheers, David
David,
Which version of AudeLA are your using?
I personally use an old but working version with Atik camera (through ASCOM, version SP1): 20120312
You can get it on Source Forge here: http://sourceforge.net/projects/audela/ ... e/download
Work well with Atik Titan, Atik 314L+ or Atik 460EX cameras...
http://www.shelyak.com/en/
